Alfa 147 GTA, unable to connect to dash.
Posted: 08 Jan 2014, 23:40
Hi all.
I was trying to do a proxy alignment on my 147 GTA 03, but it will not connect to dashboard node. When I try to connect directly to the dash nodes i get error "elm327 - ecu com fail."
Any Ideas? everything is working as it should on the dash and car. And yes I do have full version of multiecuscan 1.8.
Thanks!
Here is the log for proxy alignment:
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
0
0
0
0
0
0
Writing to module: Dashboard Node (NQS) FAILED! - Timeout error
Writing to module: Driver Door Node (NPG) SUCCESS!
Writing to module: Climate Control Node (NCL) SUCCESS!
FAILED TO EXECUTE
Thanks!
0
0
0
0
0
0
FAILED TO EXECUTE
