Bug in GT 3.2, Parameters and Actuators
Sedicivalvole
Post by Sedicivalvole »
When the program I have already connected to the car, I can not select any parameters or actuator. I try to select the squares but not marked, then it is impossible to make graphs and logs. Another problem: not detected the engine running, many are still values to 0.
The other functions are correct, I can turn on and off the lights in the box, try some engine components ...
Thanks for a great work!
smyrnote
Re: Bug in GT 3.2, Parameters and Actuators
Post by smyrnote »
probably the same problem. i just tried parameters and i couldn't select any parameters. i tried 3.3 and 3.4.2...
