Vagkkl interface cable /Multipla /searching for odometer km
Posted: 08 Oct 2013, 09:30
by loopdemack
Hello I would like to buy a used multipla bipower cng 2002-2003 year and I bought Vagkkl interface cable:
www.imagebam.com/image/0a9ad8280308832
My idea was that I hunt for the odometer km on dashboard, engine, abs and airbags but:
I played in simulation mode and in simulation in Multiecusacn 1.4 version I can only see engine, abs and airbags there is no dashboard and body (proxy alignment for example)
www.imagebam.com/image/c776ca280308839
Do we have in multipla at all the dashboard, services, body, climate control and other system ecu options like on punto, bravo and other Fiat cars.
Or is this just it? Or its just like that in the simulation or with this particular interface.
Could I at all access in the dashboard and services if multipla have it at all, or do I need elm327?
In which places multipla writes the mileage odometer? And how can I access in all of them?
Please I need help, I need to understand this. Thank you.
Re: Vagkkl interface cable /Multipla /searching for odometer
Posted: 09 Oct 2013, 21:25
by alfa156sarajevo
So you need to connect MES with engine ECU on Fiat Multipla.
Open the Parameters section (F4) and at the end of parameters list you will see "Odometer" and "Odometer at last rewrite" options.
Select them and there you will see the real kilometres.
Compare them with one on dashboard and you will see the difference.
In general kilometres in engine ECU are always less then one in dashboard...
Posted: 09 Oct 2013, 23:15
by loopdemack
I know where are odometer parameters in Engine ecu.
I'm trying to find out how could I connect to body, service and dashboard ecu system and also I'm trying to find out how can I see parameters like km from abs and airbags like on Stilo models which I saw on Examiner.
Posted: 10 Oct 2013, 18:05
In MES only the ECU, ABS and airbag is supported for your Multipla
You can read all this with your KKL interface switchable
I do not think the example the air conditioning is supported
But press nevertheless simply times when the switch is set to 1/9.
Whether an air conditioner is found.
I do not think.
AlfaOBD can read from heating Multipla
Posted: 11 Oct 2013, 00:39
by loopdemack
Alfaeddy wrote:Hello
I do not think.
@Alfa could you tell me do you know why is so hard for developers to include the dashboard, service and body ecu system modules for Multipla.
Its nice to see that ALFAODB has more available modules for ECU systems than multiecuscan
Posted: 11 Oct 2013, 13:47
I can not tell you unfortunately
There is always interest in the area of the developer with whom he deals controls, and controls for which he writes his program.
Just write directly Yani and inquiries?
Posted: 14 Oct 2013, 18:52
by alfa156sarajevo
loopdemack wrote:I know where are odometer parameters in Engine ecu.
Unfortunately those things are not supported by MES...
