I'm looking for some help.
I as far as I can see have installed everything properly, after just buying the registered version on multiscan.
When I try to do a proxy realignment, It will work fine with all of the parts, apart from the dashboard, then says that it has timed out :/
Any suggestions, really appreciate any help!
Thanks,
Gaz
Proxi alignment timeout
Re: Proxi alignment timeout
Any one?
Do you have problem with some part on your car or you did proxy just to try it?
