Do not combine with alpha gtv and I can not connect to the airbag sensor
TRW 60625181
PINS:
9 - K
14 - GND
15 - 12V
multisecuscan is compatible ?
hallo alfa GTV sensor airbag 60625181 not connect
Re: hallo alfa GTV sensor airbag 60625181 not connect
It sould support Airbag system for GTV.
But to be 100% sure you need someone to check it on your car directly and then you will know...
On some cars works without any problems, but on other ones it does not work..
