Graph / Data logging Feature
Kendoville
Post by Kendoville »
It would be good, as a marker and indicator, if a line was plotted on a graph when a fault code appears on the system during data monitoring. This would distinguish exactly when an error / fault has occurred and pinpoint what was happening at that time with other signals. Possible?
Re: Graph / Data logging Feature
Good idea and certainly possible.
What I don't know is the ability and latency involved to scan for errors/fault codes whilst doing real time signal monitoring.
If I were doing this then I would be looking for fault codes as a minor issue but certainly focussing on trying to detect the EML signal.
Only Yani or someone else with detailed experience of ECU data reading can reply in any detail.
