Reset service Stilo Mjtd is not available in free version
Pandadance
Post by Pandadance »
I have installed Multiecuscan 1.6 but reset service and the oil change reset (DPF) is not available for the Stilo Mjtd. They are only in the registered version.
It's correct? In the list of the "supported vehicles/system" these functions are supported!
Thanks for your help.
In any case, excellent product
Re: Reset service Stilo Mjtd is not available in free versio
Please chexk again the supported vehicles lists.
Itens in RED require a registered/paid for version of MultiECUScan.
Check here: http://www.multiecuscan.net/SupportedVehiclesList.aspx
If you stil have a problem then please post back.
Nick /////
Pandadance
s130 wrote:Please chexk again the supported vehicles lists.
Nick /////
In the the supported vehicles lists, under "Fiat Stilo 1.9 JTD/Multijet 16V", "Bosch EDC16C39 CF4/EOBD Diesel Injection (1.9, 2.4)" and "Service Interval Reset" are in black!!!
Even if a controller with free version can be read from Multiecuscan
(Black font)
Does it not all functions are to use it.
This you can see in the list on the home page of Multiecuscan
vysej861
Post by vysej861 »
I have the registered version of multiecuscan. I was under the impression I would be able to reset the service clock using this on my fiat doblo 1.9 multijet diesel 2007. However although on testing the interface I have a valid elm327 com 3 connection which says is available in all can modes, I cannot access the service reset. It just will not connect.
Can some one please advise me on what I can do and if I am doing anything wrong.
I should also mention it reads the engine mode fine
