Elm 327 v.1.5 (V Gate Bluetooth) Connect problem
Jordandc
Post by Jordandc »
Hi Everybody.
I have a problem with connect by this interface to Abs,service,clima and every other option by multiecuscan v1.5. I can connect only to engine. I also was bought adapter yellow 1,9 can. Also not working.
My car Grande Punto 2008 1,4 8v.
Also tried with Linea 2007 1,4 8v also can connect just engine.
I want to remove service inspection: ,,Service Coupon Expired"
I was read that some ppl is removing any resistor from his interfaces. But I can't find this one in my interface.
Full hd pics
http://images62.fotosik.pl/60/ec4abcdfaf360b76.jpg
http://images64.fotosik.pl/60/6e2db83e1ae898dc.jpg
http://images65.fotosik.pl/60/8a650b2c8df82291.jpg
http://images64.fotosik.pl/60/b7c345c306ef88a9.jpg
This was cheap one from ebay.
Cost 10$
Thx in advance for help.
Re: Elm 327 v.1.5 (V Gate Bluetooth) Connect problem
Hello Jordanodc
In this thread is about the same interface as your
Although your pictures are better, but I can not pursue traces still
viewtopic.php?f=5&t=1493&view=unread#unread
Also, I can not recognize which contacts the white plug
OBD Pin 6 and Pin 14 are?
Your pictures are good but I can not see how the MCP2551 chip was installed anyway.
And I enlarge your images, the unclear
It may not be the bridge resistor this interface has no one ?
And there is only one driver or setting problem??
Once use this driver :-)
In the pictures I can not follow the tracks and do not see how the MCP2551 is connected.
For all Windows versions of 2:08:30 is needed! 32 + 64 bit
The driver is required so that your PC can work with the interface
whether the connection via BT or USB cable is not relevant
Jordandc
Post by Jordandc »
so if my elm is connecting with engine by multiecuscan i need to have installed this driver too?
i make another pics and i think now will be good
http://images64.fotosik.pl/61/eea3afdc2c9c75d7.jpg
http://images61.fotosik.pl/61/6200dd60d62c42e0.jpg
http://images65.fotosik.pl/61/f5bacb1282cc56a4.jpg
http://images61.fotosik.pl/61/74d06a1f6f959571.jpg
When Linea the ECU and the ABS is not read via CAN bus
Therefore, this is not a problem on the bridge resistance
And for the ABS of the Linea, you need the adapter A1 (green)
In your pictures, I can not follow, because the are not bigger and sharper
as the first pictures.
Also must go where the pin 6 +14 on the board just knowledge.
Jordandc
Post by Jordandc »
Linea connrcting with engine nothing else.
I know that linea need green one.
but i have punto grande and adapter yellow not connecting.
So My elm is good so why nothing work Just engine.
I need to make better pictures for you?
If i connect with gp engine i have 7 bookmarks
if with linea engine i have 2 bookmarks.errors and first i forgot name.
I make betterpics tomorrow.
I have your picture labeled times, pins 6 and 14 are correct?
I see the image in the conductors are transmitted to the back of the board.
I will therefore probably can not see, but it's worth a try
6e2db83e1ae898dc beschriftet.jpg (79.19 KiB) Viewed 12524 times
Jordandc
Post by Jordandc »
pins 6 14 is same how you Show on picture.
Jordandc
Post by Jordandc »
this is back side i signed it same numbers as your ring
6e2db83e1ae898dc beschriftet.jpg (80.9 KiB) Viewed 12513 times
