Hi All,
I have set of adapters and ELM327 which seems to work for all computer modules.Under full sets I mean green , red and yellow adapters wtih fixed ELM327 module.
Strange for me is when I connect green adapter and connect to ABS/VDC system module , the connection is ok but in the same time of execution connection communication to the module , on the dashboard display it display that ABS, ESP ASR modules disconnected and the respective lights for the modules are on .No any erros have been shown in the ABS computer module and when I push F11 or disconnect button of Fiat ECU scan it automatically connect that modules and lights on dashboard disappeard/switched off.
The question is , Is it normall when you connect to the ABS ASR computer module , the programm to disconnect that modules , and ones you exit or disconnect from the ABS computer to activate them again?
Thank you in advance for the answers
Fiat Bravo 2007 1,9Mjet ABS ASR disconnected
Re: Fiat Bravo 2007 1,9Mjet ABS ASR disconnected
Some modules are deactivated when in diagnosis, also with the "official" diagnosis.
@ asus
Even with other diagnostics equipment and with other brands and models these things are happening and it is completely normal.
