hi chaps!!
I have attempted to help a fellow Fiat club member out with a couple of things using multiscan. We needed to do a proxy alignment, but this fails with error "configuration not support by system error"...what??! this is the log:
CAN CONFIGURATION DATA:
00 02 01 6F 00 02 01 6F 00 00 01 03 00 00 01 03 00 00 00 00
00 02 01 6F 00 00 00 09 00 02 01 6F 00 00 00 01 00 00 00 09
30 34 31 39 32 30 31 35 37 33 39 54 45 52 4D 3A 31 37 20 20 20 20 03 10 29 6F 01 02 00 09 00 00 00 D3 00 00 00 00 14 26 00 00 00 44 06 00 00 00 00 00 00 00 11 58 43
Body Computer Node (NBC)
Engine Control Node (NCM)
Electric Steering Node (NGE)
Dashboard Node (NQS)
Brake System Node (NFR)
Driver Door Node (NPG)
Passenger Door Node (NPP)
23/06/2013 10:03:51
CONNECTED TO:
FIAT STILO 1.9 JTD
Body Computer Node (NBC):
Engine Control Node (NCM):
Electric Steering Node (NGE):
Dashboard Node (NQS):
Receiver Radio/Radio Navigator Node (NRR/RMN):
Brake System Node (NFR):
Driver Door Node (NPG):
Passenger Door Node (NPP):
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Body Computer Node (NBC) FAILED! - Configuration not supported by system error
FAILED TO EXECUTE
FAILED TO EXECUTE
does any one have any ideas about this??
Fiat Stilo MW Proxi Alignment failed
Re: Fiat Stilo MW Proxi Alignment failed
bump..anyone??
so nobody knows what this error is?? can nobody help?
What kind of adjustments has been made before so you needed to do PROXY?
hi, the chap I was helping had a new dashboard fitted due to his old one failing...
Yep. Dashboards can die on Stilos.
Sometimes happened to me the same thing, message "failed", but I turn key off for some seconds and later I can see no blinking display and rpm and speed needles are working fine. Obviously it is a bug in MES.
