Fuel pump
slimtomi
Fuel pump
Post by slimtomi »
Hello!
I'm not sure it is a bug I just noticed it. I choose IAW 1AB ECU
When I make a test on RPM counter or fuel vapour cut-off valve the fuel pump starts to work at the same time. I think that is not normal.
Yani:
When I'm testing RPM counter it stands at 3750. It was checked with a Solus diagnostic tool 1 year ago and it was the same (3750). So I think this is an authentic value.
If you want you can add this information to the description in MES.
So if we read a different value of this (for example 4000) we can see there is a problem with the RPM counter. This is just an idea.
And we are still waiting for self-adaptation reset function to be added to MES :)
Have a nice day guys!
