I released Multiecuscan 1.5 today with the following changes:
- Added support for adapter 4 (purple) for modules which use k-line on pin 13
- Support for Magneti Marelli IAW 1AF Injection (1.6 16V) (Bravo/Brava, Marea, Palio, Delta)
- Support for Magneti Marelli IAW 1AB Injection (1.6 16V) (Marea)
- Support for Visteon CF4/EOBD Diesel Injection (2.2) (Ducato 250)
- Support for Bosch ABS 8 ESP (Grande Punto, 500, Fiorino, Qubo) (Full support)
- Support for Bosch ABS 8 ESP 2 (Grande Punto, Evo, Mito) (Full support)
- Support for Bosch ABS 9 (Ypsilon 2011, Ducato 250 Facelift)
- Support for Bosch ABS 9 ESP (Ypsilon 2011, Ducato 250 Facelift)
- Support for ZF 4HP18K Automatic Gearbox (Alfa 164, Lancia K)
- For MULTIPLEXED/CANtieCAR users - fixed connection problems with latest interface firmwares
Multiecuscan 1.5 released
Re: Multiecuscan 1.5 released
Multiecuscan 1.5
I'm very satisfied.I have cantecar interface multiplexer and the specified version 1.5 .Fiat Punto Klasik A/C Dinamic 1.2l 8v.
Fiat Punto Clasic A/C dinamic (188) 1.2L 8V YER 2009. IAW5AF HW603 SERBIA
CANtieCAR + Multiecuscan
For anyone looking for an adaptor 4 cable for the pin 13 coverage - Gendan received their first batch into stock today.
They should be live on the website and ebay this week.
See the MES distributors list for details
As you said Yani, 1 Month. I'm buying it now. I hope it works well!
Thank you very much! Great job!
I have a driver IAW 1AF and I can not connect.The report sen
It seems that you are running the program in "High Latency Mode". Please uncheck this option in Multiecuscan Settings and try again.kobra wrote:I have a driver IAW 1AF and I can not connect.The report sen
Beautiful thanks.
Works
Great respect for the work of your
Works
At lastyani wrote: - Support for Magneti Marelli IAW 1AF Injection (1.6 16V) (Bravo/Brava, Marea, Palio, Delta)
Hí Yani ,
Some vehicles manufactured in Brazil and Argentina ( mercosul ) FIAT STILO 1.8 16V, have ECU engine DELPHI - HSFI 2.3
not supported by multiecuscan yet.
Waiting in the next release.
hi can someone PLEASE explain to me a dtc code B0118 of fiat 500 year 2008 CAUSE ON SOME SITES THEY SAY ITS THE SIDE AIRBAG AND ON MULTIECUSCAN SAY ITS THE FRONT IMPACT SENSOR,THANKS
