hardwear problem!!??
156er
Post by 156er »
Yoop,
I've just bought a cable via e-bay. I've got a problem with this cable, there is a pice of black wire with no connection at the end.
Is there anybody, who know where is this wire going to?
Thanks a lot
Zsolt from Hungary
Re: hardwear problem!!??
Hello 156er
The cable was already so in orders?
Strange!
As well has anyone tried to modify an interface and it failed
The cable must be connected from pin 3 on the boards separately input (switch).
You've been sold a tinkering solution!
156er
Post by 156er »
It is a "stock" chinese item :) number1 quality as always.... so anyway, it seems that wire must go to that point....
Hello 156er
I've got some KKL interface from China
But none of them has been so bad and with additional cables, such as your interface
The cable must not be soldered to the location marked by you
The input of the circuit board is the left of the 4 bars to the board
But pin 3 must not be soldered directly this pin is read as airbag.
I do not know this building boards
156er
Post by 156er »
This is a cable with a switch on it. Same item.... http://www.ebay.com/itm/VAG-KKL-USB-OBD ... 90&vxp=mtr
Hello 156er
I did not know that this is a KKL interface with switch. Sorry
Then this loose cable must be soldered to those of you red marked spot.
yes that is correct
