Multiecuscan 1.4 RELEASED!
I released Multiecuscan 1.4 today with the following changes:
- Added support for more than 8 colors on the graphs
- Fixed incorrect support for TRW Airbag in Ducato 250 Facelift
- Support for Parking Control BOSCH (Doblo, Fiorino, Ducato, Qubo)
- Support for Marelli 8F3 CF5/EOBD Diesel Injection (2.3) (Ducato)
- Support for Bosch EDC17CP52 CF5/EOBD Diesel Injection (3.0) (Ducato)
- Support for Marelli SELESPEED CFC348 Automatic Gearbox (Ducato)
- Support for Magneti Marelli IAW 8GSF CF5/EOBD Injection (0.9) (500, Ypsilon 2011)
- Support for Magneti Marelli IAW 8GMF CF5/EOBD Injection (1.4 16V) (Bravo, Delta)
- Support for AISIN TIP-System Automatic Gearbox (Lybra)
- Support for Electric Hood Control DURA (Spider) NOTE: You will need a modified interface (or adapter) with connection to pin 13 for this module. Currently this pin is not supported on any of the 3 adapter cables.
- Support for Tyre Pressure Control (TPMS) TRW (Grande Punto, Evo, Mito, )
- Support for DTC Details of Marelli 8F3 CF5/EOBD Diesel Injection (1.3)
- Support for DTC Details of Marelli 8F3 CF5/EOBD Diesel Injection (2.3)
- Support for DTC Details of Marelli 8DF CF5/EOBD Diesel Injection (1.3)
- Support for DTC Details of Marelli 6F3 EOBD Diesel Injection
- Support for DTC Details of Bosch Motronic Me7.9.10 CF5/EOBD Injection (1.4 16V)
- Support for DTC Details of Bosch EDC16C39 CF5/EOBD Diesel Injection (1.6, 2.0)
- Support for DTC Details of Bosch EDC16C39 CF4/EOBD Diesel Injection (1.9 8V)
- Support for DTC Details of Bosch EDC17CP52 CF5/EOBD Diesel Injection (3.0)
- Support for DTC Details of Magneti Marelli IAW 8GSF CF5/EOBD Injection (0.9)
- Support for DTC Details of Magneti Marelli IAW 8GMF CF5/EOBD Injection (1.4 16V)
- Support for DTC Details of Magneti Marelli IAW 5SF3 CF4/EOBD Injection (8V)
- Support for DTC Details of Magneti Marelli IAW 5SF8 CF5/EOBD Injection (8V)
- Support for DTC Details of Parking Control VALEO
- Support for DTC Details of Parking Control BOSCH
- Support for DTC Details of Marelli SELESPEED CFC328 Automatic Gearbox
- Support for DTC Details of Marelli SELESPEED CFC300 Automatic Gearbox
- Support for DTC Details of Marelli SELESPEED CFC228F Automatic Gearbox
- Support for DTC Details of Marelli SELESPEED CFC218F GTA Automatic Gearbox
- Support for DTC Details of Marelli SELESPEED CFC208F (1) Automatic Gearbox
- Support for DTC Details of Marelli SELESPEED CFC348 Automatic Gearbox
- Support for DTC Details of Marelli SELESPEED/DDCT CFC8TDF Automatic Gearbox
- Support for DTC Details of AISIN Q-System Automatic Gearbox
- Support for DTC Details of AISIN TIP-System Automatic Gearbox
- Support for DTC Details of Body Computer Delphi
- Support for DTC Details of TRW Airbag (Ep - PROXI)
- Support for DTC Details of TRW MY05 Airbag (Ep - PROXI)
- Support for DTC Details of SIEMENS MY06 Airbag (Ep - PROXI)
- Support for DTC Details of CONTINENTAL Airbag 2 (Ep - PROXI)
- Support for DTC Details of AUTOLIV MY07 Airbag (Ep - PROXI)
- Support for DTC Details of CONTINENTAL Airbag (Ep - PROXI)
- Support for DTC Details of Delphi Electric Steering
- Support for DTC Details of Tyre Pressure Control TRW
There are also a few fixed errors in the parameters of various ECUs which were reported by the users, but I lost track of these small fixes.
Regards,
bgunn
Re: Multiecuscan 1.4 RELEASED!
Post by bgunn »
Many thanks for your update, specifically (from my point of view) of the TwinAir engines being supported :)
emmerich1234
Post by emmerich1234 »
How do I udate from licensed 1.2R?
Thx
emmerich1234 wrote:How do I udate from licensed 1.2R?
Thx
I sent you an email.
stolekap
Post by stolekap »
Many thanks for your update,More support engine management - Magneti Marelli IAW 4AF/4EF/59F/5AF
Fiat Punto Clasic A/C dinamic (188) 1.2L 8V YER 2009. IAW5AF HW603 SERBIA
CANtieCAR + Multiecuscan
dave798
Post by dave798 »
Hi how do i upgrade from multiecuscan 1.3?
Upgrading from 1.n to 1.m is very easy.
1) Do NOT uninstall 1.n (1.3)
2) Ensure 1.n (1.3) is not running
3) Run the 1.m (1.4) Install program
UNLESS otherwise advised all upgrades will be a simple "install over" process.
argtv6
Post by argtv6 »
Yani,
there is a 3-pin connector for the hood in the rear battery compartment. Is a a modified interface (or adapter) still needed here?
Ralph
alain laurent
Post by alain laurent »
Bonjour
j ai installer la mise a jour 1.4 et ma licence n est plus bonne ? que faire le nouveaux code est 020900740905-0570
alain laurent
I have installed the update 1.4 and my license is no longer good? that make the new code is 020900740905-0570
alain Laurent (English translation added by S130)
argtv6 wrote:- Support for Electric Hood Control DURA (Spider) NOTE: You will need a modified interface (or adapter) with connection to pin 13 for this module. Currently this pin is not supported on any of the 3 adapter cables.
Yani,
Ralph
No, for cars with 3-pin connectors you don't need modified interface. You only need the 3-pin adapter.
