Deactivate Emergency Stop Signal
Mazza-Engineering
Post by Mazza-Engineering »
Hello Yani,
I was trying to deactivate the Emergency Stop Signal ESS (Blinking of indicators when you hard press the brake).
I thought it was a function in ECU, but unfortunately it is not.
The ESS will be handled by the Body Computer.
The BC monitors following conditions:
- deceleration >7 m/s² (+/-0,5 m/s²)
- vehicle speed >50 km/h
- no blinking light active
- vehicle speed sensor not damaged
If all of these conditions are true, BC will start sending the signal for ESS.
They will blink with a higher frequency than normal blinking.
If BC recognize a deceleration <2,5 m/s² (+/-0,5 m/s²) it will stop generating ESS.
Now my question is:
do you have access to single areas in BC memory?
I suggest to rise up the vehicle speed condition of >50km/h to e.g. 150 km/h or 200 km/h
I'm fully to your disposal and would like to help wherever it is possible.
Best regards
Luca
Mazza-Engineering
Re: Deactivate Emergency Stop Signal
Hello yani,
any answer regarding this matter?
Best regards
Luca
Mazza-Engineering
Hello yani,
I don't want to be impolite, but I wrote you even a PN and didn't get any answer.
A simple yes or no would be enough.
I thought being a registered member would speed things up, but it doesn't look like.
Really a pity.
I now know which bit to change in the configuration to deactivate ESS but I don't know how to write it back in BC.
I'm not sure if you are interested in an solution in this issue. But for sure a lot of people will be interested in this and will be willing to pay even extra money for that.
Waiting for you feedback
