Lancia Thesis dashboard node (NQS) failure
Posted: 16 Apr 2013, 19:41
Hi All,
I just ran the proxi alignment procedure on a Lancia Thesis 2.4 20v because the cd player was exanged. Afterwards we got an EOL error indicated on the dashboard. I´ve got the following report
CAN CONFIGURATION DATA:
00 02 F7 5B 00 02 F7 5B 00 00 44 40 00 00 40 40 00 00 00 00
00 02 F7 5B 00 00 00 09 00 02 F7 5B 00 00 00 09 00 00 00 09
30 31 31 31 35 30 30 30 32 38 37 4F 55 54 50 55 54 2D 4A 49 54 20 02 10 17 5B F7 02 00 09 00 00 00 00 00 03 12 42 00 00 00 00 00 23 50 20
CURRENTLY CONFIGURED CAN MODULES:
Body Computer Node (NBC)
Engine Control Node (NCM)
Dashboard Node (NQS)
Steering Wheel Controls Node (NVO)
Brake System Node (NFR)
Driver Door Node (NPG)
Boot Node (NVB)
Climate Control Node (NCL)
Steering Angle Sensor Node (NAS)
Parking Brake Control Node (NPB)
Ceiling Node (NIM)
Side Acceler./Yaw Node (NYL)
Passenger Door Node (NPP)
CURRENTLY AVAILABLE CAN MODULES:
Boot Node (NVB)
Ceiling Node (NIM)
CAN MODULES THAT REQUIRE EOL PROGRAMMING:
16-4-2013 20:59:00
CONNECTED TO:
Lancia Thesis 2.4 20V
CURRENTLY CONFIGURED CAN MODULES::
Body Computer Node (NBC):
Engine Control Node (NCM):
Dashboard Node (NQS):
Steering Wheel Controls Node (NVO):
Brake System Node (NFR):
Driver Door Node (NPG):
Boot Node (NVB):
Climate Control Node (NCL):
Steering Angle Sensor Node (NAS):
Parking Brake Control Node (NPB):
Ceiling Node (NIM):
Side Acceler./Yaw Node (NYL):
Passenger Door Node (NPP):
CURRENTLY AVAILABLE CAN MODULES::
Boot Node (NVB):
Ceiling Node (NIM):
CAN MODULES THAT REQUIRE EOL PROGRAMMING::
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Dashboard Node (NQS) FAILED! - Timeout error
FAILED TO EXECUTE
Any help on what the Dashboard Node is, or what else could be wrong is very much appreciated!!
Thanks in advance!
Boot Node (NVB)
Ceiling Node (NIM)
Boot Node (NVB)
Ceiling Node (NIM)
16-4-2013 20:59:00
CONNECTED TO:
Boot Node (NVB):
Ceiling Node (NIM):
Boot Node (NVB):
Ceiling Node (NIM):
FAILED TO EXECUTE
Thanks in advance!
