My ELM has always functioned without a problem. Now, after I connected it to my Grande Punto, I cannot connect anymore to engine modules. The other modules with the yellow or green adapters are working fine. Also I tried to connect to an 156 jtd. There is also no connection.
Message: ELM to interface fail connection. Check interface or port adjustment (or something like this).
Connection problem ELM
Re: Connection problem ELM
Thanks Yani for the reply!
Can you please tell me what could be the issue? Connection does not work! Also not with tke kkl.
The same happens with me on a Doblo JTD 2002 EDC15 C7.
It is not possible to connect with kkl or elm. to trouble shoot i connected with alfa diag and works fine.
For can modules no problem. It is not possible only connect to the engine.
Yani, can you help.
Regards,
Alfiat
Yani, can you help.
Regards,
Alfiat
Solved.
It was conflict between two adapters with FTDI chip.
For me closed.
Regards,
alfiat
For me closed.
Regards,
alfiat
