Yes I did and get invalid ISO code and some parameters are showing wrong like odometer, battery voltage, speed....
I get some errors but I afraid to clear errors.
i will be happy if I get correct parameters without invalid ISo codes.
If you can connect it with other Ducato model than it is good.
Do no worry you can delete errors - nothing bad will happen...
Sometimes when you are connecting with other ecus you only have number of error code but if you are lucky you have also description of errors…
