Greetings to all, courtesy a question, can you tell me if the program Multiecuscan can be installed on an Apple computer? (Macbook)
thanks
Macbook
Re: Macbook
This sfotware requires Microsoft .NET installed on a PC to function.
I'm not a MAC specialist so all I can suggest is if you can find on the internet of software that will allow .NET based applications to run on a MAC.
Re: Macbook
s130 wrote:This sfotware requires Microsoft .NET installed on a PC to function.
Thank You!!!!
Re: Macbook
You are welcome.
PLEASE NOTE THIS POINT!
Yani / MES may use the Windows Registry for registration keys and other puposes. I've done a quick registry scan and can't see anything obvious but that does not mean that the reistry is not used.
If the registry is used then you may have to look at installing "Paralles" / similer and the Windows on top of that.
I STRONGLY suggest you downlooad and experiment with the free version of MES. If you can get it to run then please CONTACT MES Support BEFORE attempting to buy a license. It is possible that registration technology could fail in what ever environment you can get running.
Best of luck.....Nick
