Fiat marea weekend help
Kna84
Post by Kna84 »
Hi i bought the VAG Usb obd2 and the software just gives me access to the Abs and airbag and i need some help to install the cable. Can't connect to the ECU.
Fiat marea weekend 2002
This is the item i bought
http://www.ebay.com/itm/FIAT-ALFA-VAG-U ... 3f2236c908
Sorry for My bad english
Re: Fiat marea weekend help
To connect with the ECU you have to make the switch to the number 7
The airbag on the number 3
and the ABS, the number 1/9
You should install this driver
And Latency Time set to 1 (previously 16)
Then set the COM port of the interface in Multiecuscan.
And set in Multiecuscan the KKL.
Kna84
Post by Kna84 »
Dont work connection failed :(
Try it once with a second laptop
Kna84
Post by Kna84 »
Tried whit another laptop and could access Abs and airbag. When i Scan i find the engine iso number but i can't get access to engine ECU. Check Cable and usb port. Could it be something in the ECU to the engine that dosen't work ???
Either this! The control device has an error
Or your Marea a controller has the MES is not supported?
This would Yani can say something
Kna84
Post by Kna84 »
Sorry for asking but what is MES ???
MES = MultiECUScan
Rest is self evident.
I have been testing Marea Weekend 1.6 petrol and I always had problem connecting to some engine ECUs.
I eave did contacted Yani directly via e-mail and his respond was that some KKL interfaces can not connect to engine ECU.
Since my KKL interface was older one I did ordered new one and when it came I did teset it on the same Marea Weekned. And it worked perfectly. But the problem was when I did test it one month later it would not connect any more.
At the end I give up.
It could always connect to abs and airbag ECU but just did not want to connect to engine ECU.
As I could see from my experience in past few years it does not have any rule when it will work and when it will not work on all Mareas. On some models you can connect to engine no matter is it running engine or the key is in MAR position. On other models works only when the key is in MAR position, and on some models just does not work! :roll:
