How to make a vag-com cable?
leopold89
Post by leopold89 »
Aron96
Re: How to make a vag-com cable?
Post by Aron96 »
Hello Leopold 89, as vag com you should use the 409, but most say that the car you want to diagnose what to do because you could also serve the elm 327 + adapters for both the vag, the more info
Hello Leopold89
By KKL VAG com or interface, the controls are read glesen still using an older protocol.
e.g. My97 airbag or the M2.10.3 / 4 etc.
Otherwise the newer controllers with a protocol which is also read read the ELM.
Today's control systems are read with CAN Bus
leopold89 wrote:How to make a vag-com cable?
Try to find it on Google. I am sure there you can find at least few electronic schemes with details and photos how to make it.
I know when I was starting 3-4 years ago I wanted to make myself ELM and VAG interface...
Some parts I could not find immediately... I had to order and to wait for them...
At the end I figured out that is easy to buy than to make it by yourself.
Aron96
Post by Aron96 »
After translating the request of Leopold good, I must say that I confirm the answer alfa156sarajevo in fact already on the cables at low cost
