I own a OBDLink Interface since a few days the firmware is updated. I tried to connect my Fiat Doblo 1.9 JTD Multijet (120PS, Type 119) but the only module I can connect is ECU. I want to reset the service module but the connection fails. As you show in the "supported vehicle list" I only need a elm 327 1.3 interface to connect the service module. I think the OBDLink is compatible to elm 327 1.3. The USB settings is on a low latency time of 1 and a transferrate of 115.200.
Please I need your help. What can I do.
Connecting Problem with OBDLink Interface!
Re: Connecting Problem with OBDLink Interface!
Hello Landy, service maintenance can be restored only with the registered version,
Hi Landy
Multiecuscan should only show in a frame when the registered version is required?
Can you connect to "CAN info" produce?
This should also work with the free version.!
Otherwise, listen to your problem, like so many ELM327 Interface?
CAN Bus Problem
but for that I would need to view the board.
CAN Bus Problem
Thank you for quick response.
I update the multiecuscan registered Version to Multiecuscan therefore I think I it is also a registered Multiecuscan.
Next time I will try to connect to "Can Info" and refer.
