Service Reset on Panda 4x4 1.3 Mjt 75cv DPF
Posted: 10 Jan 2013, 20:47
by gioz
I had a problem with Service Reset on Fiat Panda 4x4 (M.Y.2010) 1.3 multijet 75cv 4x4 DPF (Marelli 8DF).
The Automatic Service Reset was well but when I try to set the value "distance of next oil change" manually, its fail.
All other value were changed correctly, only problem is the distance of next oil change :(
I attached the log.
FESLog_1301101916_Fiat Panda '03 1.3 JTDMultijet.txt
Service Reset LOG
(1.26 KiB) Downloaded 153 times
In addiction, this model of Panda which isn't present in the vehicle list and I have scanned the ecu with Panda 03 JTD/Multijet --> Marelli 8DF CF5/EOBD Diesel Injiection (1.3) but give "Invalid ISO Code". This causes the fail of Adjustments : "Oil change (only DPF version)" and the relatives oil parameters (example % Degrade oil) dont'change.
I attached another log.
FESLog_1301101905_Fiat Panda '03 1.3 JTDMultijet.txt
Oil Change LOG
(793 Bytes) Downloaded 143 times
Please, give me a solutions?
Thanks a lot!
Re: Service Reset on Panda 4x4 1.3 Mjt 75cv DPF
Posted: 11 Jan 2013, 15:05
by alfa156sarajevo
Regarding your first part of post from above, I did mentioned few months ago to Yani that on Panda it is not possible to do manual adjustment for option "distance of next oil change".
Since I was working on petrol car for me was just fine service coupon.
I hope it will be possible in near future... ;)
Posted: 11 Jan 2013, 17:01
by yani
About the service reset:
Did you try to change "Service interval" (Lettura intervallo servizi) and "Service period" to lower values? I added these 2 adjustments since Multiecuscan 1.1 to fix the problem with vehicles where the other two adjustments do not work. You may need to execute "NEXT SERVICE KM RESET" and/or turn the key OFF and then back ON after setting the new values.
About the engine oil change:
This is the correct ECU for your engine. It shouldn't give you Invalid ISO message. There was a bug with some ISO codes in previous versions. Do you use the latest version of Multiecuscan?
Also, what is the value of "Oil change counter"?
Posted: 11 Jan 2013, 21:35
by gioz
yani wrote:About the service reset:
Ops, I don't have tryed to change "Service Interval" but "distance of next service"! I have resolved whit "service interval", excuse me, works well!
I don't changed the value "Service Period" because this value not appear in the Instrument Cluster, only value showed is remaining km to next service (Service Interval).
yani wrote:About the engine oil change:
I used Multiecuscan 1.1.
Today I installed the last version and Invalid ISO message as disappeared.
I execute again the Adjustments "Oil change (only DPF version)" and "Oil Change Couter" rose from 1.9% to 100%.
Works well! :D
alfa156sarajevo wrote:Regarding your first part of post from above, I did mentioned few months ago to Yani that on Panda it is not possible to do manual adjustment for option "distance of next oil change".
Hi, you tryed "Service Interval" Adjustments? On my Panda works perfectly! The distance next oil change is changed!
Thanks a lot for soonest reply and assistance!
Best Regards!
