Hello there
I have a FIat Panda 2007 1.2 8v 60ps, gasoline.
I have a blinking engne light on my dashboard, and although i have full access to the ECU e.t.c.
It cant find any faults.
Does Multiecuscan identifies non permanent errors ?
Fiat Panda My'07 Blinking Light
Re: Fiat Panda My'07 Blinking Light
Hello NGT, the case for replacing the timing belt, sometimes it happens that the indicator light flashes injection without errors in this case you have to learn the chin phonic wheel, but if you do not do too lai changed this procedure, the procedure has also described the in multiecuscan
I agree with Aron96. Try to reset phonic wheel...
