i have suzuki grand vitara 2010 eng 2.4L
and i bougth this elm 327 from amazon
http://www.amazon.com/BestDealUSA-ELM32 ... USB+OBD+II
but notwork ( no vehicle response)
elm 327 proplme
Re: elm 327 proplme
Hello the Grand Vitara is not in the list!
Only the SX4 and including the
1.9 DDiS and 2.0 DDiS
But no 2.4 engine!
But no 2.4 engine!
Re: elm 327 proplme
Eddy, will it work with a 2015 vitara 1.6 ddis ? In case it does, what can I read from the ABS module ?
thanks
thanks
Re: elm 327 proplme
Ok then reading should be possible.
To know what to read in the ABS.
Download Multiecuscan in the free version and
Make a simulation with the ABS of your model
Re: elm 327 proplme
Okay, dlded and ran simulation. I have a couple of questions:
1. why does elm327.ro sell the licence cheaper than you do on the main site ? 199 ron is less than 50 euros. Are they still legitimate ?
2. and what if the software fails to talk to the suzuki, do I get moneyback if I produce a video with it not doing the job ?
3. What I was after were individual travel distance by each wheel. I can track each wheel's speed I can see, but not each wheel travelled distance. Is there any way to determine that, maybe via logs, graphs - that could work if there were enough readings per second. How many readings per second can I expect of a cheap chinese bluetooth elm 327 dongle ?
thanks again!
thanks again!
Re: elm 327 proplme
I'm trying to give you answers, even though your questions should be the Mod or Yani.
To 1st currency differences ??
To 2. I am no Mod or Admin here, but I think times bought is bought, and why should the reading with your Suzuki not work?
In other vehicles it is also
To 3. Therefore, I have you with the simulation to see what data you can read and again said most Chinese ELM interface does not work with Multiecuscan
