Multiecuscan 1.2R1 will fix the license problems in Multiecuscan 1.2!
I released Multiecuscan 1.2 today with the following changes:
- Added support for WiFi interfaces (ELM327, OBD, OBDKey)
- Added possibility to select a parameter for the X axis of a 2D graph
- Added 16x16 map generation based on the data recorded from vehicle. Please note that this function uses interpolated data and may not be accurate!
- Added Cruise control activation function for the newer Grande Punto (>2008) in CAN Setup/PROXI Alignment
- Improved support for Magneti Marelli IAW 4AF/4EF/59F/5AF EOBD Injection
- Fixed incorrect parameter readings for TRW Electric Power Steering (3) (Stilo, Bravo, Idea, Delta, Musa)
- Fixed incorrect parameter readings for Bosch MSA 11 Diesel Injection (2.4) (Marea, Lancia K)
- Support for Bosch Motronic M1.7 Injection (Croma '92, 155, 164, Thema '92) (Full support)
- Support for Magneti Marelli IAW 7GF Injection (Idea, Linea, Uno 2010)
- Support for Delphi Electric Steering (Ypsilon 2011)
- Support for Instrument Panel Continental (Ypsilon 2011) (Info and DTC only)
- Support for Instrument Panel Marelli (Ducato 250 facelift) (Info and DTC only)
- Support for Instrument Panel/Body Computer Continental (Uno 2010) (Info and DTC only)
- Support for DTC Details of Bosch Motronic Me7.3.1 EOBD Injection
- Support for DTC Details of Bosch Motronic Me7.3.1 EOBD Injection (1 lambda)
- Support for DTC Details of Hitachi MPI injection (EOBD)
- Support for DTC Details of Magneti Marelli IAW 4AF/4EF/59F/5AF EOBD Injection
- Support for DTC Details of Bosch Motronic ME 3.1 EOBD (2.0, 2.4)
- Support for DTC Details of Bosch Motronic ME 3.1 EOBD (3.0 V6)
- Support for DTC Details of Bosch Motronic ME7.3H4 EOBD Injection
- Support for DTC Details of Bosch Motronic ME7.3H4M EOBD Injection
- Support for DTC Details of Magneti Marelli IAW 4SF Injection
- Support for DTC Details of Magneti Marelli IAW 5SF CF4/EOBD Injection
- Support for DTC Details of Bosch Motronic Me7.9.10 CF5/EOBD Injection (1.4)
Multiecuscan 1.2 RELEASED!
Re: Multiecuscan 1.2 RELEASED!
After todays update i have FREE version instead REGISTERED.
BAS
BAS
Please download Multiecuscan 1.2R1... it should fix the problem.bas wrote:After todays update i have FREE version instead REGISTERED.
BAS
Works ok.yani wrote:Please download Multiecuscan 1.2R1... it should fix the problem.
BAS
Big Update!
I always wanted the "map generator" and i can't wait to test it out
If you can fix the EGT function on bosch me7.9.10 introduced few versions ago...not displaying any value, a zero neither, would be great
thank for your hard work!!
Please note that the MAP is not accurate and will not match the actual maps inside the ECU... It is based on the live data from ECU with some rounding and interpolation... Of course I will try to improve the accuracy in future versions and will add enchancements to this function (like user-entered list of X and Y values).EnIgMa wrote:Big Update!![]()
I always wanted the "map generator" and i can't wait to test it out![]()
Me7.9.10 on which car? It is different in Grande Punto and Bravo...
Lucas EPIC DCU3F - simulation mode still hangs MES...
Sorry, I forgot about this one...tzok wrote:Lucas EPIC DCU3F - simulation mode still hangs MES...
it will be fineyani wrote:Please note that the MAP is not accurate and will not match the actual maps inside the ECU... It is based on the live data from ECU with some rounding and interpolation... Of course I will try to improve the accuracy in future versions and will add enchancements to this function (like user-entered list of X and Y values).EnIgMa wrote:Big Update!![]()
a table with real data is ok, there is no need to extract data from the map....well if it will be possible i wont say no.
Sorry if i aways forgot to write the car model:
bosch me7.9.10 on grande punto 1.4 turbo
edit:
i've just tried this new version on simulated mode..
I think there is no need to "interpolate" the values as long as you allow to create a table with a single column/row if only 2 values are recorded/viewed, of course you have to choose which one is in X or Y AND the value inside the cells.
3 values is X; Y; Z <-- no interpolation here.
in the future, maybe, 4 values on 3D visualization.
ah, can you put in the next version the possibility to lock the "Z" value (the cells value) to the max value?
For example, RPM VS IntakePressure on turbo engine, flatout from 2000rpm to limiter:
While the engine is revving the pressure will be >0bar but just after i lift the throttle all the cells will be rewritten with like -0,8bar all the way down.
yani, Take pity on owners Fiat Brava/Bravo 1.6 16V and add support IAW 1AF!
