ALPHA 147 Selespeed Airbag conn ELM327 V 1.4
mattpaulin
Post by mattpaulin »
Hi, I have a 2002 Alpha 147 Selespeed. I have the licenced copy of Multiecuscan. Connection is via an ELM 327 v1.4 Bluetooth Module. I ve made the mods for pins 1,3, and 12 to pin 7. Can connect to the following ECU's, Engine, Gearbox, Climate control, ABS, Dashboard, Body, Drivers Door and Boot. CANNOT connect to headlights or Airbag :cry: . Airbag light is on - I want to know which sensor... Can you help?
Matt
Re: ALPHA 147 Selespeed Airbag conn ELM327 V 1.4
For your Alfa 147 you need a KKL interface to read the airbag
That is not gone with the ELM interface
The pin 3 is not required to ELM
Purchase a KKL and change the connection from pin 7 to pin 3
Only the pin 3
So you can read your airbag
