Congratulations on this exciting new software. It looks very good and I'm happy that it now supports M.155 ECUs.
But not for me, at least, not yet. So please help.
I tried to connect to my Alfa Romeo 2.0 TS 16V 1999 with a M.155 but it keeps disconnecting everytime I try to read the sensors. I can see the ECU data information and error codes but as soon as I try to read the sensor data or erase the error or reset the actuator it disconnects. I lowered the COM port latency time to 1 but it didn't help.
Also, there are 2 different M.155 ECUs to choose from, one says '98 and seems to work. If I choose the other I get wrong ISO code when I connect. Which one is the correct for my car and how do I know?
Cheers,
Marcos
Help with version 1.6 and M.1.5.5
Re: Help with version 1.6 and M.1.5.5
Hello!
Many thanks for this great soft, especially with free version which looks much better than Unidiag.
But, (there always a but I've got the same problem like BR-Scan, in almost every detail (I've got Alfa156 1.8 TS 2000).
I suppose i shouldn't use definitions which tells that ISO code is invalid, obviously.
That '98 defs connects without any errors but if i only mark a parameter to check it disconnects.
What's going on?
Thanks in advance.
What's going on?
Thanks in advance.
Hello Maser,maser wrote:Hello!
What's going on?
Thanks in advance.
I fixed this when I started to use the ELM327 interface, no more disconnections, works like a dream with my 156 2.0 1999. My ELM 327 is a clone, not the genuine chip, but even though it works fine. If you don't have ELM you should get one, it's worth, and I recommed the genuine one, which I'm also getting.
Cheers!
Hello BR-Scan!Hello Maser,
Cheers!
Thanks for explanation and guidelines!
I've got VAG-KKL cable only.
I read that ELM327 is for newer ECUs - cars made after 2001. Also heard it doesn't work with Alfadiag and Unidiag so I've just bought VAG
Now, I'm looking for an answer, maybe I'll find it.
Cheers.
