Multiecuscan 1.1 RELEASED!
Well, Multiecuscan 1.1 has problems with some MULTIPLEXED licenses.. So we released Multiecuscan 1.1R1 to fix this problem!
I released Multiecuscan 1.1 today with the following changes:
- Improved SCAN function
- Added support for OBD-Direct/Protect interface
- Added possibility to change Sevice Distance (on almost all vehicles) and Service Period (on some vehicles) in Service Interval Reset modules
- Added Logistic Mode control for Panda, Croma and 159 Body Computers
- Added parameters for injection quantity, time, advance of all 5 injections in some multijet engines
- Added the generation and export of CSV file with engine parameters during DPF regeneration
- Support for Marelli climate control (Stilo, Bravo) (Full support)
- Support for Marelli 8DF CF5/EOBD Diesel Injection (1.3) (Panda, Idea, Ypsilon, Musa)
- Support for Bosch Motronic ML4.1 Injection (GTV, Spider, 164)
- Support for Bosch Monomotronic MA1.7 Injection (Fiorino, Tempra, Tipo, Uno, Delta, Y10)
- Support for Magneti Marelli IAW 4GF BI-Power Injection (Multipla)
- Support for Magneti Marelli IAW 4GF BLU-Power Injection (Multipla, Marea)
- Support for Driver's Door G.E. PROCOND (Brera)
- Support for Passenger's Door G.E. PROCOND (Brera)
- Support for Driver's Seat LEAR (Giulietta) (Info and DTC only)
- Support for Passenger's Seat LEAR (Giulietta) (Info and DTC only)
- Support for DTC Details of Bosch Motronic MED7.11 EOBD Injection
- Support for DTC Details of Bosch Motronic MeD7.6.1 CF4/EOBD Injection
- Support for DTC Details of Bosch Motronic MeD7.6.2 CF4/EOBD Injection
- Support for DTC Details of Bosch Motronic MeD17.3.1 CF5/EOBD Injection
- Support for DTC Details of Marelli 6JF EOBD Diesel Injection
- Support for DTC Details of Bosch EDC16C39 CF5/EOBD Diesel Injection
Regards,
Re: Multiecuscan 1.1 RELEASED!
Hi Yani,
There is bug in MES 1.1R1 regarding airbag system on FIat Multipla 1.6 16V from 2000.
I did try on MES 1.1R1 and on FES 3.6.2 and problem was the same. I just could not connect.
I did try to use next systems:
- BREED MY97 Airbag – does not work
- Allied MY97 Airbag – does not work
- SIEMENS MY99 Airbag – does not work
Unfortunately I did not have time to try next models: Allied Signal Airbag and TRW MY97 Airbag.
Of course I did use VAG COM KKL interface and red adaptor A2 and I did not have any luck.
Would be nice if you could check it...
Thanks ;)
Antonio
Post by Antonio »
Hi Yani,
my Y10 (1995 , engine code: 176b.2000 - CEE FASE 2 - EURO 2) have Bosch Monomotronic MA 1.7.2 this release support my injection?
I did not want to open new topic because there is no need for it... so Yani I have few questions for you:
- do you know what could be a problem when I can not connect to engine ecu while engine is running?
Tried it on few fiats, Fiat Marea 1.6 petrol and Fiat Bravo 1.2 petrol, both made in 1999.
I can connect when the key is in MAR position (ignition ON) but as soon as I start engine it would not connect.
I have no idea is this a bug or maybe some problem with engine ecu?
Tried to connect with MES 1.r1 but no connection. Tried to connect with FES 3.6.2 but no response from ecu while engie is running.
Any info would be helpful.
teris
Post by teris »
Hello!!
I have KKL interface ..and I have this situation (see in attach) when I make test!!!
I m not check it yet, on a fiat car..but I connect the cable in another car to take power 12v.
Maybe I have problem or not?
I have not fiat car to check it !!
What I must do it if I have wrong settings??
Can you help me please??
fiat ecu scan.rar
(75.1 KiB) Downloaded 456 times
Thanks in advance!!!
alfa156sarajevo wrote:I did not want to open new topic because there is no need for it... so Yani I have few questions for you:
I will answer myself since I fount what was the problem...
The problem was in the KKL interface. Obviously they do not work too long so it would be good if you can always have one KKL and one LEM interface extra... just in case something like this happens... :roll:
yong lupy
Post by yong lupy »
hello
iam new working on fiat
i want to solve the fiat coupe 20V turbo 1999
which cheap interpace can use?
i have VAG usb kkl.
doest it working with Multiecuscan 1.1 RELEASED! software.??
thankyou
yong lupy
Post by yong lupy »
yong lupy wrote:hello
i have VAG usb kkl.
thankyou
and please help me..
thankyou :) :) :) :)
Look here: http://www.multiecuscan.net/SupportedVehiclesList.aspx and you will see that the Coupe 20V Turbo is supported.
The Motronic ECU requires a purchased/registered version of MES to be able to connect to the ECU.
KKL interface and 3-pin adapter cable required.
