I am not able to to do Gearbox Diagnosis on Punto 1.2 Speedgear ELX (99-03). Kindly advise as I have one customer in my workshop and i need to sort out his gearbox.
Thank you.
Re: Punto 1.2 Speedgear ELX (99-03)
The auto gearbox in Punto Mk2 is FUJI SG-CVT and it is not yet supported in Multiecuscan.
If you want to check the error codes then you should be able to connect to the gearbox and check the error codes by selecting "Punto '03 1.2 8V" and "Selespeed CFC208F gerabox". Please note, however, that if you read the errors this way then the descriptions will not be correct. You can post your error codes here and I will give you the meaning of each error code.
