Bravo '07 Parking sensor info on screen
Posted: 03 Oct 2012, 20:23
by Mankio
Hi all,
some months ago I saw an Alfa MiTo video in which there was a parking sensor info on the matrix screen, and knowing that about 90% of electronics used in Bravo, Delta and Mito were the same, I wanted to try enabling on my Bravo that already has matrix screen and parking sensors.
Two days ago, I went in the "CAN Setup / PROXY Alignment Procedure", set the "Parking sensor info on screen" to "enabled" and made the PROXY ALIGNMENT.
EXECUTING ADJUSTMENT...
Old value: Disabled
New value: Enabled
COMPLETED
PROXI ALIGNMENT PROCEDURE
Writing to module: Dashboard Node (NQS) SUCCESS!
Writing to module: Info-Telematic/Convergence Node (NIT/NCV) SUCCESS!
Writing to module: Climate Control Node (NCL) SUCCESS!
Writing to module: Airbag Node (NAB) SUCCESS!
COMPLETED
As you can see, the procedure went fine, but once I tried to switch to the reverse gear, nothing appeared on the display and the usual intermittent buzzer was not heard anymore.
I reverted the setting to "disable", made again the alignment procedure, and the intermittent buzzer was back.
Is there something that I'm missing? Maybe that I need a different dashboard?
Thanks in advance
Re: Bravo '07 Parking sensor info on screen
Posted: 04 Oct 2012, 14:36
by fiatbravoemotion
In Bravo this option turn off buzzer. Any information is not displayed on dashboard, matrix dasbhoard too. In Mito or Alfa 159 this option display information about sensors onto matrix display. In Bravo only turn off buzzer.
Posted: 04 Oct 2012, 15:26
by Mankio
Thank you for your quick response.
My hope was that I could enable the info, but seems that I have to forget about it because changing the dashboard in not in my plans ;)
