some months ago I saw an Alfa MiTo video in which there was a parking sensor info on the matrix screen, and knowing that about 90% of electronics used in Bravo, Delta and Mito were the same, I wanted to try enabling on my Bravo that already has matrix screen and parking sensors.
Two days ago, I went in the "CAN Setup / PROXY Alignment Procedure", set the "Parking sensor info on screen" to "enabled" and made the PROXY ALIGNMENT.
As you can see, the procedure went fine, but once I tried to switch to the reverse gear, nothing appeared on the display and the usual intermittent buzzer was not heard anymore.EXECUTING ADJUSTMENT...
Old value: Disabled
New value: Enabled
COMPLETED
PROXI ALIGNMENT PROCEDURE
Writing to module: Info-Telematic/Convergence Node (NIT/NCV) SUCCESS!
Writing to module: Climate Control Node (NCL) SUCCESS!
Writing to module: Airbag Node (NAB) SUCCESS!
COMPLETED
I reverted the setting to "disable", made again the alignment procedure, and the intermittent buzzer was back.
Is there something that I'm missing? Maybe that I need a different dashboard?
Thanks in advance
