hi yani
did try to connect electric powersteering pin 7 k line to pin 9 eobd
my stilo mw 2003 eps did not reply , did check hardwire connection this was ok
any one else luck with this eps connection on a stilo , let me now !!
wilco1v -- holland
stilo 1,6 mw connection with agv4000 kkl modus
Re: stilo 1,6 mw connection with agv4000 kkl modus
i use a automade very ceap KL serial interface and it work great...
I also connect directly with the EPS ecu because i have no body. (only the eps fitted on a race car)
i made the jumper between the 7 (obd k line standard) and 9 (fiat k line) directly into the interface connector..
if you know about electronics or some of your friends, i could sand you the schematic for it.. But it have only the RS232(serial) interface..
Bye Bye
Matteo
Bye Bye
Matteo
Registered 2.8.2 Italian user and EPS specialist
