Torque calibration don't work for the delphi flat eps
Teos81
Post by Teos81 »
i try the new function for the torque calibration with some delphi eps..
into le last one that have the sensor with the flat cable, (like punto evo, last 500 and last grande punto) it didn't work..
could you please check it??
Thanks a lot
Best Regard
Matteo
Registered 2.8.2 Italian user and EPS specialist
Re: Torque calibration don't work for the delphi flat eps
Does it give you an error message?
Teos81
Post by Teos81 »
Hi, sorry for the late answare but i made some test also into other car (last 500, punto evo, New Punto and mito..).
All the Delphi eps with flat sensor the calibration abort quickly with "FAILED TO EXECUTE" error...
I also check with an external canbus protocol analizer and the eps ecu reply with the code that don't understand the command (i don't remeber now, but it is like 07Eh)
It only work for the old 500 and grande punto with the external wire sensor...
Let me know if you find some upgrade..
Thanks a lot
Bye
Matteo
