help me use multiscan
Posted: 26 Aug 2012, 16:37
by giovanni60
Hello everyone, I need help because I do not work the multiscan.
I bought an ELM 327 Ver 1.4, which will show you the pictures, I downloaded the free program
and I bought the licenza.Ho controlled the communications port that is com2 and is set to 38400.
After starting the program I checked the setting of the interfaces, making the test.
The program gives me access only to motor control and I'm not making me do reset the service interval as well as other functions.
When I connect to the service interval reset tells me to check the port settings, pin OBD adequate.
What should I do?
Help, thanks
RESPONSE: ATZ
ELM327 v1.4
ELM327 v1.4
Questa interfaccia รจ compatibile con ELM 327 1.4! Dovrebbe collegarsi correttamente con tutti i moduli CAN.
Re: help me use multiscan
Posted: 26 Aug 2012, 17:14
by yani
Please check the following thread and write about this problem there:
viewtopic.php?f=5&t=1493
Posted: 26 Aug 2012, 18:24
In this thread, just a few days ago this interface was treated.
Posted: 27 Aug 2012, 19:56
by giovanni60
Hello Eddy, I saw the thread but my ELM327 is different from those reported, and still a friend of mine bought the same from the same dealer has the software and a license but had no problema.cosa I could check?
Thanks for your help
Posted: 27 Aug 2012, 21:59
Hello Giovanni
What control to which vehicle has read your friend then?
Because of Faulty resistance only prevents the CAN Bus Protocol
All other protocols are not affected
