agv4ooo via kkl on stilo mw 1.6 connected
wilco1v
Post by wilco1v »
hi yani
i,m happy to write that i have used your soft on my car stilo mw 1.6 16v 2003 to test engine ecu
i have used the usb -- agv 4000 exp version in the kkl modus on my asus netbook (Com6)
direct great result on screen ,thanx
my agv4000 11protocol (and can emulate elm functionality)
see stange distribution (or tunerpro24) for the agv4000 info
i use mostly modiag (expert) on the agv4000(real good eobd soft)
runs on canbus on my stilo
update :tested with dip selector (k line 7 to pin *.* )
dip pin on = 1 eobd ABS , connection ok
dip pin on = 3 eobd airbag , connection ok
dip pin on = 7 eobd engine , connection ok
dip pin on = 9 eobd electric powerstering , connection NO !!! on my car ????
need advice for connection to stilo powerstering
wilco1v (holland)
bas
Re: agv4ooo via kkl on stilo mw 1.6 connected
Post by bas »
You have to disconnect cable from pin7 to connect to powerstering.
BAS
wilco1v
Post by wilco1v »
bas wrote:You have to disconnect cable from pin7 to connect to powerstering.
BAS
hi bas
k line 7 was already diverted to pin 9 >>> powerstering still no readings for me
thanx any way
greets wilco1v
bas
Post by bas »
BAS
hi bas
thanx any way
greets wilco1v
Strangely, for me (Vag kkl) disconnecting from the other pins solved the problem.
BAS
