2.4 JTDM
vesku
2.4 JTDM
Post by vesku »
thank's a lot for a fantastic tool!
I connected ver 1.6 to alfa 159 2.4 JTDM 2007
All actual values seem to be OK, except the odometer is totally wrong.
But most of the actuators do not follw the commands. e.g. none of the signal lamps came me on and fan 1 didn't start. I tested it power on but engine not running. Any idea what's going wrong? I also connected the pins 1-3-7-9 together but only the engine ecu is available. I suppose it is as it should be, at least only the engine ecu is mentioned in your list of supported vehicles.
br
vesku
tomsa
Re: 2.4 JTDM
Post by tomsa »
the same at my 159 1.9 JTDm from 2006. Actors are not working, odometer is =0, everything else seems to be o.k.
Hopefully will be fixed in future releases of this great tool.
Tomsa
http://tomsa.bplaced.net
vesku
Re: 2.4 JTDM
Post by vesku »
I think there is a big difference between 156 and 159, when 159 is using the CAN-bus. Connection to engine ECU was quite good in 159 also.
