Before you start procedure just check with FES is the cruise light working or not - connect to dashboard!
After that just go to: FIAT > STILO 1.9JTD > Body > CAN Setup / PROXI Alignment Procedure > Adjustments (F7) > Cruise control light > click Execute (F10) > choose: Enabled > go to: PROXI Alignment Procedure > click Execute (F10) > when you got success to all systems than turn the key OFF > wait for 15-30 seconds > turn key ON > turn the cruise switch on - it should be on!
