hi
i cant get any of the parameters to show..
baude 9600
no software ver. no nothing..
it does connect and read fault codes
ELM 327 1.4
no working parameters?
Re: no working parameters?
oh and i cant datalog them either not even rpm.. when chosen it just shows 0 in the graph..
tested the EGR acuvator and it did open an close!
What car and what module are you connecting to?
Did the software give an invalid ISO code warning as it connected?
no errors.. id did say under test that this would not be able to connect to CAN
car fiat panda 1.3mjet 2004
elm327 1.4
choise 1.3+
elm327 1.4
choise 1.3+
...and which module on the car are you connecting to?
Have you run a scan to check that the module you are selecting is the one reported as being present by the car?
