Information on adjustment functionality
otraper
Post by otraper »
I am interested on buying the registered version of Multiecuscan to use it with Lancia Thesis car but before doing it I would like to known what is possible to do with it and the correct interface. More specifically I have not found any informationon about the adjustment functionality for the Automatic transmission module.at
So i am requesting to everybody is alreadyfamiliar with to provide a description of what is possible to do by using thata functionality. Any help is appreciated and
support my final decision to spend money on the Multiecuscan program.
Regards
Sandro
Re: Information on adjustment functionality
Firstly look at the support vehicles list of modules supported.
Secondly, download the free version of Multiecuscan.
Now when you run the free version you can go into "simulation mode". To do this you connect to a module with the CTRL pressed (control key pressed).
Now you can view all the possible options, functions etc. that are supported.
Go have a play!
otraper
Post by otraper »
I already have the free version of the program. But I would like to better understand if the adjustment functionality is capable to
perform automatic transmission calibration (adjustment) in the same way as the OEM tester do!
Thank You.
All I can see for the Thesis Auto Gearbox is the "Self Learn Function"
I have no idea if this is what you are looking for.
I think Yani will have to respond in more detail to answer your question.
