No parameter reset?
Benzina159
No parameter reset?
Post by Benzina159 »
Hi, does FES have a ECU parameter reset option on the Alfa Romeo 147 1.9JTDM because i cant seem to find it? i remember the option being available on the 159 2.2 JTS
Re: No parameter reset?
Reset self learnt functions on the Adjustments tab? Is this what you are looking for.
Benzina159
well on the 159 it was called reset ecu parameters but it sounds like the same thing, is this option your talking about available for the 147?
On the 147 1.9 JTD then we have two engines. The 8V and 16V.
The only Engine ECU on the 8V or 16V engine that Multiecuscan supports the function you are after is on the Bosch EDC16C39-CF4 ecu.
If could be that this reset function is avaialble on the other ECUs used on the 147 but FES does not yet support it. Only Yani will know.
A far as I know for MJET engines (EDC16 C39 CF4) you only have "Reset Self-Learnt Functions".
Maybe it is helpful to you?!?
Just go to this topic: viewtopic.php?f=6&t=3092
There you can see the photo...
