Lancia support
Zubrania
Lancia support
Post by Zubrania »
Hello thank you for great job
I have couple of questions
Do you plan to support the following
1) Controlled Damping suspension (Magnetti Marelli McA 200) were installed on lancia Kappa Coupe and sedan
2) Code system
3) m 2.10.4 ECU
Thank you in advance
A Bart
Re: Lancia support
Post by A Bart »
This is intresting.
I have 2 kappas too,(and alfa 156)
2.4 berlina -96 and 2.0 turbo Sw -99.
Those older needs difrent connection socket, 3 pin fiat based.
Wondering how to connect this wondeful software to my kappa.
I order vag cable to try it my alfa.
Zubrania
Re: Lancia support
Post by Zubrania »
Currently Engine ECUs are not supported
In next release yani told that will add abs CU support
Airbags CU are supported now if I'm not mistaken
Suspension is currently supported only by Examiner
A Bart
Re: Lancia support
Post by A Bart »
Conneting to older fiat 3 pin socket is very easy. :o
I try simple (cheap) obd to 3 pin wire, and try connect to my kappa.
Connection is made but not work in my free version.
How can i simulate this to see what i can do with this?
Zubrania
Re: Lancia support
Post by Zubrania »
Yani, Could you probably pay your attention on one of the unsupported modules of Lancia Kappa like Controlled Damping suspension (Magnetti Marelli McA 200) were installed on lancia Kappa Coupe and sedan
A Bart
Re: Lancia support
Post by A Bart »
Yes, and alarm system for kappa too.
Now i have something fail about this.
Central locking working, but lights are not always flash.
Sipea alarm battery too low maybe? :?
