As you're coding this software you do know well all those rs232/elm and whatever protocols and devices. do you?
As i know elm327 should support various speed/latency or stuff like that.
Is it possible to add a "performance" test into settings window to perform and automatic test?
So FES can automatically determine the best settings for each device we use...
Maybe a couple of sets.
One for pure performance even if there a certain amount of errors
One for best stability or "reliability" of data
Because you know, sometimes more data per seconds you get, the better
What do you think Yani?
Then, related to what i just said above:
is it possible to set a priority for each parameter?
For example I want to datalog rpm/boost and air temperature...
First 2 parameters vary very quickly but the third one does not.
So it's a kind of waste to read the temperature every cycle of readings...
If i could set 1^ priority for rpm and boost and 10^ to temp. it could read rpm/boost each cycle BUT air temp. every 10 cycles...
or another example would be
spark advance every cycle (so 1st priority)
engine load (2nd...every 2 cycle)
and air temp. (20^...every 20 cycle)
Playing with cycles reading you can almost get a lot of data where needed and less where the value changes slowly...
cheers
