Hitachi ECU and KKL-usb cable
hi guys,
i hawe problem with connection. This is my first connection with this software (multiecuscan16). I use VAG KKL-interface USB cable (work on VWgroup with IHR30HO and VAG-COM 409.1, K line is on pin 7), use netbook Acer aspire with Win XP, CPU 1,66Ghz, ram 1GB, car is Fiat Coupe 1,8 16V 98 wiht Hitachi ECU (it communicate with Euroscan Visa 1.83) but i can't connect?
whats wrong? Usb software? - work on VAG (simulate COM3) please help
thanx from Czech Rep.
Re: Hitachi ECU and KKL-usb cable
A podporuje tvoji jednotku ta verze softu 1,6 ????? bych typl ze ne......
v seznamu tam od uterka je ... zkusil jsem ted aktualizovat ovladace, mel jsem z roku 2004
in the list is from Tuesday's (my ECU) ... I now tried to update drivers, I had from the 2004
http://www.rawet.cz/cz/download/program ... =download5
zadna zmena, ovladace 2009
still the same, drivers 2009
what is it (bold)? FIAT COUPE' '98 1.8 16V - Hitachi MPI injection (eng. 1.8 16V '98)
don't think that your driver is the problem, looks like your cabel has FTDI chipset.
Here you can download the newest drivers:
Greets and good luck, Bu11y.
hmm thanx for new drivers, VAG (ihr and 409-1) work good on skoda felicia, bud Multiecuscan still not connect to fiat coupe 1.8 16V '98
chipset FTDI FT232BL (632-1)
Any other people with Hitachi who have problems?
Are you sure that yours is '98? Because there is an older Hitachi MPI ECU (before year 98) which is not supported.
yes I'm sure, I have version 98, all the parts in my car are versions 98, Coupe was produced as a version 96, 98 and 00, my is v. 2/98 and operates reliably on Uniscan Visa 1.83 (http://ravenia.xf.cz/euroscan-PL.zip) and Bosch KTS
Hitachi MPI MFI 46448638
...and that is definitely the old version of Hitachi MPI.von.raven wrote:yes I'm sure, I have version 98, all the parts in my car are versions 98, Coupe was produced as a version 96, 98 and 00, my is v. 2/98 and operates reliably on Uniscan Visa 1.83 (http://ravenia.xf.cz/euroscan-PL.zip) and Bosch KTS
The '98 version is marked as "HITACHI - MPI - MFI '98" in Visa Uniscan 1.83...
hmm, and will ever support for the old version 98 and 96?
I really have version 98 because 96 is different (all parts in e-per is for 98), so maybe it is the transition between versions
So, identical problem beguile. Car it year 2000, Lancia Lybra 1,8 16V ECU Hitachi. How start up?yani wrote:Any other people with Hitachi who have problems?
