i hawe problem with dashbord proxi aligment..
i put the dash with rpm meter and temerature gauge on my punto.. and the display is blinking, i try the km adjusment it`s incres the km but ecu scan wrote thet its failed.
then i try the proxi aligment, the body is oke then the dashbord aligment fail and wrote to many data..
fes is 3.4.1 i wil download 3.4.2 soon but it`s the same vith 3.2 and 3.4.1
punto mk2a 1.2 8v 2000g. proxi alignment fail
Re: punto mk2a 1.2 8v 2000g. proxi alignment fail
What was the error message when it failed? If the error is not "timeout" then it means that the new instarument cluster may not be compatible with the car.
Do Proxi from 3.4.2. I had "unknown error" when changed dashboard in Punto FL '05 from Base to Comfort on 3.3 version.
i was changing the ecu and body and dash on my punto and now is ok. but the proxi is failng again on the dashbord, the message is the same, i could send de report tomorow if needed.
Send Report after session to Yani. This in one way to help you. Information...
