Fiat Stilo default lcd screen
manic
Post by manic »
Yani, is ti possible to add to FES feature like: set default screen on lcd display. After press TRIP lcd change trip, avg speed, avg consumption etc... but after switch off engine function isn't remember and there againt iI have to press TRIP to my favorite function.
manic
Re: Fiat Stilo default lcd screen
Hi Yani,
I have few questions for you regarding Fiat Stilo JTD:
1 – Is it by any chance possible to set up the time and the date on the dashboard with FES software?
2 – Is it by any chance possible to set up the language menu on the dashboard with FES software?
The problem is that Stilo JTD had Connect Nav System fitted up by factory but someone did remove it and sold it without that to the new owner. I know how to do it with the navigation fitted up and Set Up CD…
P.S. I did not want to open the new topic for my questions so I just used this one... ;)
alfa156sarajevo wrote:Hi Yani,
What happens after you run PROXI alignment on this car? I guess that when the car "knows" that there is no CN unit It should add the missing menu settings.
Thanks Yani! I will try that and I will inform you! ;) Cheers
Yani as always you were right! I did a proxy alignment and the car went to default settings!
I could set up the time, language... Everything!
The only problem was with the service interval reset! I just could not do the coupon reset, but the main problem was solved!
Thanks once more! ;)
