my aspeedometer is not working on punto 1.2 8v
podaruc
Post by podaruc »
hello i have a big problem,
I had to change my BCM(bodeycontrol) and ECM(engindecontrolmodule)from my car with ABS and the new BCM and ECM are from a car without ABS, after the swap all is running perfect exept the speedometer.My car is a Fiat Punto from 2001 1.2 8V.
I know that the information are comming from diferent place but I allsow did put a sensor on the gearbox and the speedometer is still not working.
Pleas tell me how two resolve the problem
Best reagard,
Ciprian
PS: you are my only hope
Re: my aspeedometer is not working on punto 1.2 8v
You simply need to connect to "PROXI Alignment Procedure" and change "Speed sensor type" to ABS....
podaruc
Post by podaruc »
this only work whith 3,3 version?
podaruc
Post by podaruc »
tank you! yani
it works
