Punto 1.9 JTD 2000my Proxi Alignment Failed
bowlocks
Post by bowlocks »
I changed the dashboard node, and attempted to do a Proxi alignment. It failed. Part is a compatible part. I've done several dash swaps on petrol cars without problem. Do you have any ideas on how to proceed. If you have some beta release, I can get the car back to test it.
Thanks,
Rickey.
FESLog_1201101432_FIAT PUNTO '99 1.9 JTD.txt
(1.69 KiB) Downloaded 177 times
Re: Punto 1.9 JTD 2000my Proxi Alignment Failed
This error usually happens when you try to install an instrument clusted from gasoline car into a diesel car.
Are you sure that the new cluster is from a diesel car?
bowlocks
Post by bowlocks »
Ah, I didnt know that was not possible. I assumed because the cluster has a glow plug light in it, that it could be adapted to diesel.
Is there any way to change the coding with a soldering iron, i.e. can I put a different dump onto a processor or eeprom to make it a diesel cluster ?
Thanks,
Rickey.
Yes, you can copy the memory from the old cluster. I have not tried this method personaly, but many users say that it works 100%.
Zwierzak
Post by Zwierzak »
I think it is the same thing like with instrument cluster in panda. New instrument cluster you can put to both diesel and benzine. But used one from benzine you can't put to diesel. I don't why it happens.
In panda something is written in 95160 eeprom memory. When you download to eeprom memory data from new one it is working.
Yani can force in proxi diesel or benzine configuration?
No, unfortunately I cannot force the dashboard to accept diesel configuration when it rejects it...
However, I can "fool" it that the car is gasoline.... but this is not a good solution...
dallas140cv
Post by dallas140cv »
bowlocks wrote:Hi,
Thanks,
Rickey.
There was also the oil level indicator in the JTD cluster....
bowlocks
Post by bowlocks »
I'll let you know how I get on.
Thanks,
Rickey.
bowlocks
Post by bowlocks »
I guess its the QFP64 MCU HC08, as nothing else looks like it is or has memory ?
Rickey.
