adjust the throttle position on fiat punto1 1.2 8v
How Can i set, with the fes 3.0.3, the throttle position ? have a registered version of Fes3.0.3. Please describe the procedure.
Re: adjust the throttle position on fiat punto1 1.2 8v
Set up a connection with your ECU since
in the last panel "setting"
Is a point "reset idle adjuster"
I proceed to the description in the right box and press the
"Run" button
"Run" button
Thank you very much Eddy !
