Modificated VAG KKL cable
SpaRkY
Post by SpaRkY »
Hello!Will it has any problem if i solder pin 1 with pin 7 and in the time 3 with 7.Will i can connect to cars of VAG group and to italian cars(Alfa,Fiat,Lancia) with Engine,ABS,Airbag without any problems ?
VDLS
Re: Modificated VAG KKL cable
Post by VDLS »
For VAG cars can not have the cable pins soldiers, only for the FIAT group. For the FIAT group should only have pins 7 to 1 or 7 and 3 never do both at the same time.
SpaRkY
Post by SpaRkY »
OK.Thanks a lot
That why it is good to have adaptors (A1, A2 and A3)!
You do not need to modify the VAG COM cable!
With adaptors you can work with FIAT group and without adaptors you can work with VW group! :)
